ACZL
Oct 14, 2020Explorer
Hike, sorry for the late reply as I tore apart all the access panels and id remove the cold water line and did not find a valve you mentioned, just a fitting the line connects to which also crews into the tank. Course the dang thing is on back side of heater, so could not get a real good looksie . Sad part is, I'm kinda under the gun to get things done as it's supposed to be going into storage this Fri. At the very least, I did see where Camco markets a product where you disconnect both lines at water heater, attached the bypass line to each water line and......WOHLAA, a temp bypass.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
