schlep1967
Oct 15, 2020Nomad
Since you have the lines off an easy way to check for the check valve is to stick a screw driver in the top connection of the water heater. If it hits something solid the check valve is there. If you only have one valve the check valve needs to be there and be operating to winterize.
See this video Replace RV check valve
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
