vermilye
Oct 01, 2013Explorer
The problem with using the same wire is that it probably won't be long enough to make up the pigtails necessary to connect standard receptacles in a box. As to the method of wiring, they do make shallow, old work boxes that may fit, depending on your wall thickness.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
