vietvet66-67
Jan 01, 2014Explorer
pianotuna wrote:
Hi Taking,
Replace the return air grill on the furnace with a fan. On my rv that circulates warm "living space" air under the cabinets and pushes some air along the furnace duct work. I chose to use a dual window fan unit which is controlled by a mechanical thermostat that lives beside the water pump next to the outside wall of the RV.
The fan unit draws just 23 watts and works better than a 1500 watt fan based heater which I tried using inside the cabinet.TakingThe5th wrote:
I've been toying with the idea of installing an electric RV Furnace Enhancer from RVComfortSystems.com. It's pretty pricy but it would throw some heat into the basement and would be safer and more efficient.
Never thought of that....may steel that idea in the future.....
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
