stpettasExplorerDec 27, 2015Rv heaterOur heater goes off. Then when we turn it off and then back on it will work and then go off
TrackrigExplorer IIDec 27, 2015For members to give you good specifics answers they're going to need the year, make and model of what your RV is (you should put this in your profile) and then it would help them further if they knew the make and model of furnace.Bill
Related ContentAtwood water heater problemRV Water heaterWater Heater Replacement RecommendationsReplace insulation inside heater column.Suburban SW12DEL Water Heater On/OFF switch melts???
