stpettasExplorerDec 27, 2015Rv heaterOur heater goes off. Then when we turn it off and then back on it will work and then go off
christopherglenExplorerDec 27, 2015How long does it run before turning off and needing to be reset? Seconds? Minutes? Heats the trailer once then shuts down? How much propane is in the tanks, how many / big? Did you refill/replace them recently?
Related ContentAtwood water heater problemRV Water heaterWater Heater Replacement RecommendationsReplace insulation inside heater column.Suburban SW12DEL Water Heater On/OFF switch melts???
