ReneeG
Apr 26, 2016Explorer
janegowest wrote:ReneeG wrote:
As others have said, there is so much variable, that the most important thing is the interior layout of what you pick and if it will work for you. As for where you park and if the slides will fit, it changes.
Consider instead your lifestyle. Do you need access to your kitchen en route, at rest stops to cook? We do, so that was a must for us. We have a mid kitchen and with the slides in I can get to all appliances and the sink. One of my pantry cupboards is blocked by a slide, so I make sure that all my coffee making supplies, some water bottles, and foods are in an accessible pantry.
What about access to your shower, toilet, and bed? Will the slides in hinder it or does it matter to you?
In glancing over the other replies, maybe it would be best to visit fifth wheels, a lot, at dealerships. Ask them to bring in the slide, take a look at what you can access. What if you are en route and stop for groceries, can you put them all away easily?
Spend a lot of time looking before you decide.
Perhaps you are apprehensive on the commitment? If so, wait on your decision. Let some weeks or months pass. Time has a way of making you realize what's important.
We too, have never been in a situation where our slides were blocked at a camping site. We've had 4 TT's before our FW and three had slides.
Good luck in your decision.
Thank you very much!! Your reply was very helpful!! Yes, time HAS changed things and I am sure will continue to change...
Six months ago, I could not part with much of anything in this house. Now, I am wanting to get rid of everything!!!
But one question...can you sit on a sofa or dinette while it is closed? I read that it will damage the slide mechanism if you do....same would go for the bed, I suppose...to sleep on it with it closed at a Walmart parking lot...
You're welcome. As for sitting on the sofa, using the dinette, or bed while the slide is in - if the slide is flush with the floor when extended, then it has a different support system and use of it while the slide is in should be limited. The bed is different because it has it's own support system, which is pretty hefty. We use ours while it's in but limit use of the dinette while it's in. In other words, one of us sits on the steps to eat and the other sits at the table - less weight. Again we only do this for a lunch at a rest stop, so it's doable for us.
About Fifth Wheel Group
