14fan wrote:
We are permanent campers and just had a pad poured. What is the best thing to use to put between the tires and Cement? Would those plastic blocks at camping world be strong enough for year round use?
TIA
I mean permanent in that we will not be towing it on a regular basis, but probably will trade it in a few years.
Info posted from tire mfg doesn't cover a tire stored for several year period while still mounted. The tires simple won't last that long while sitting with weight on them. Plus they will go flat .
A google on the subject has much the same info from Tire and Rubber Manufacturers Association and tire makers .....and you don't have to read through off topic comments.
Hopefully you plan to block the trailer up for long term ??
