- spud1957ExplorerNew truck option. See my original post.
- JohnHeinzExplorerI see. Thanks for the tip, 4x4ord! I'll keep that in mind.
- 4x4ordExplorer IIIYup. That’s how I use mine. It buys you a little extra cab to trailer front clearance and seems to handle just fine. The difference between putting 3000 lbs of pin weight 2 inches behind the axle centre and two inches ahead of the rear axle centre is minimal. 2 inches in front puts 37.5 lbs of that 3000 on the front axle where as behind takes 37.5 lbs off the front axle. One way the rear axle carries 2963 lbs the other way it carries 3038 lbs.
Edit: the above assumes the pucks are centred over the rear axle but I think they might be about 2 inches ahead of Center to start with. So it still would make a difference of 75 lbs to the front axle one way vs the other but angled back would put the pin directly over the rear axle vs angled forward would put the pin 4 inches ahead of centre .... putting 75 lbs to the front.
About Fifth Wheel Group
19,025 PostsLatest Activity: Sep 03, 2025
