ependydad
Mar 01, 2018Explorer
MFL wrote:
Welcome to the forum Ana!
I doubt many would use that truck to tow the size/weight FW you are talking about. With a dry wt of 10K+, the loaded weight could easily be 12K. This could put 2,400+ lbs right over your rear axle, and is not including the hitch wt, or cargo/passengers in the truck. Your truck's entire payload will be around 1,500 lbs.
Jerry
I agree with Jerry. Running the dry weight numbers through TowingPlanner.com, you're looking at a wet loaded pin weight in the ballpark of just shy of 2,600 lbs.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
