Devind33
Aug 06, 2017Explorer
Sagging floor
My 2012 razorback 2650 toy hauler the floor has started to sag in the middle. You can't really see it but you can feel the hump near the front and on the sides. It sinks down about 3/8"-1/2". Shoul...
roller183 wrote:
A suggestion if you plan on leaving toys in the TH all winter and not moving them would be to lay a piece of 3/4" plywood under the wheels that are on top of a area of floor, not near a floor joist or cross member.
This would help spread the load to the cross member and possibly not bow the floor material(osb/pressboard-thin plywood)as much or at all. Make sure the extra plywood spans from joist/cross member to the next cross member.
Plywood in winter-moist areas will sag from weight over a extended period of time, leaving you with those small dips in the floor.
