Devind33's avatar
Devind33
Sagging floor
My 2012 razorback 2650 toy hauler the floor has started to sag in the middle. You can't really see it but you can feel the hump near the front and on the sides. It sinks down about 3/8"-1/2". Should I be concerned or is this normal? I got underneath the trailer and the integrity of the beams all look just fine
  • Moisture readings are normal???
    What moisture readings are you taking?
  • I would never be dishonest like that even to a dealer. I did check and the moisture readings were normal.
  • Trade it in as soon as possible.
    You have a water leak that has already caused massive damage. The leak is probably tiny, undetectable, impossible to find, and impossible to fix...let alone the massive amount or work it would be to find the damage in the roof, walls, and floor.
    Don't tell the dealer about the sag or the leak.
    Take the hit now...hopefully it won't be too bad.
    Unload it while you still can.
