cummins2014
Feb 28, 2019Explorer
Cummins12V98 wrote:
"He repeated that I would be best served by weighing the trailer and use the tables - he said that's what they are they for."
Blasphemy I say!!!
You mean Sailun recommends using the weight/inflation tables as GY does??? Difference is Sailun says add 10% and GY says add 5psi to what the chart says.
This just can't be. :R
Ron, just curious, where you are coming up with that 10% thing on Sailun. I have a inflation chart , the Sailun rep. sent me, and don't see anything mentioned about 10%. It does mention that the given pressures for the weights is the minimum to use. I run 100 psi, 10% would put me at max air pressure 110
About Fifth Wheel Group
