nremtp143
Mar 01, 2019Explorer
cummins2014 wrote:Cummins12V98 wrote:
"I wonder if this isn't a major CYA from Goodyear after those bad years with some of their tires."
Give GY Tech a call and tell them you are going from load range "E" that is at it's carrying capacity. Then tell them you are going to a "G" tire. Then ask them what tire pressure should you run.
They will tell you to use the chart based on the heaviest tire on each axle and add 5psi to the chart pressure.
I did this in 2010 when going from GY "E" to GY "G" tires. I ran the "G" tires at 85psi for thousands of miles with perfect tread wear. optimal braking and ride.
I have NEVER had a flat or blow out using GY US Made "E", "G" or "H" tire. I did loose some of the center section of my GY "H" tire, they replaced it.
On every tire I based psi on LOAD.
For whatever reasons, those G614's are still blowing out, although I ran a set on the present fifth wheel for 6 years.
Reason I said anything about the G614's , and anyone can go look on the thread I started on the Montana owners forum. Guy came on that thread with pictures of his G614 blowout, unlike mine which was not a blowout . No doubt with his, there was a patrolman following behind , and he said it sounded like it scared the patrolman more then it did him . If in doubt go take a look at his tire, not too bad ,no damage to trailer, but definitely a blowout.
This is my story of my GY G614. Was running a TST TPMS that alerted me the instant of the BOOM. I was being followed by a State Trooper that saw nothing that I ran over, although the blowout scared both he and I, nothing was found in the roadway. Some have said it looked like the tire had been curbed. to which I say I could see that if it were the door/curb side of the rig, not the driver's side front. However, tires are tires and they all will fail eventually. How they fail is up to us as consumers to mitigate as we can get the best tire for the money, with the best load carrying capacity with safety margin, keep them at max pressure, inspect them often and run a TPMS system when we are traveling. Oh, and missing all the holes and debris in the road we can.
About Fifth Wheel Group
