caysea7254
Jun 20, 2017Explorer
Sailun Tires ?
Just got our Sailun tires on our 2015 337 RLS Refection. Question is our Westlake psi we kept at 80, do these need to be any more than that? Thanks Tara
fj12ryder wrote:Lantley wrote:They did not, although they were more even than I had expected. I had 4 that weighed 2,000 lbs., and 2 that weighed 2,500 lbs. The heavier 2 were on opposite sides and not on the same axle.fj12ryder wrote:
I don't know about anyone else, but I weighed mine. Seemed like the easiest way. I have the Shurline scale rated to 5,000 lbs. and weighed each wheel.
Did they all weigh the same? I imagine they did not?
I seriously considered going with "E" rated LT tires after I found out what my weights were. However I kept getting advice that I was not supposed to have any tire that was rated less than the OEM tires. Which, of course, were the "E" rated ST tires which self-destructed after less than 2 years. But with my weights/tire and the carrying capacity of 3,000 lbs./tire I would have been fine I think. However the Sailuns have been great and I have no complaints whatsoever. Maybe a bit of a rough ride, but I'm not even positive about that.
fj12ryder wrote:Lantley wrote:I don't know about anyone else, but I weighed mine. Seemed like the easiest way. I have the Shurline scale rated to 5,000 lbs. and weighed each wheel.B.O. Plenty wrote:
Running more air than is needed is no big deal to me. I want the max load carrying capacity and the least amount of sidewall flex. Sidewalls flexing generates heat which kills the tire. I don't think you will ever wear a tire on a trailer out because it is over inflated. They will wear unevenly if the alignment is off or they will time out from old age. I always run my tires at max inflation. Never had a problem, just my opinion.
B.O.
I agree and inflate the same way.
For those attempting to match pressure to the weight of the tires, how are you determining the load carried by each tire?
B.O.
mapguy wrote:caysea7254 wrote:
Mapguy where do we find the load & inflation guide for Sailun tires? Thanks
From Sailun -requet it through their website.
B.O.
