caysea7254's avatar
caysea7254
Sailun Tires ?
Just got our Sailun tires on our 2015 337 RLS Refection. Question is our Westlake psi we kept at 80, do these need to be any more than that? Thanks Tara
  • What amount of weight is on the tires? That will help determine what pressure to run them at. I only have about 2500 lbs. on each tire and run around 90-95 psi. Some folks run lower, but I would feel uncomfortable running under 90 psi. But that's just me.
  • I am assuming that yours, like mine, are probably the 235/80 (or 85) -16 G rated tires. If so, the maximum pressure is 110 psi. I am running my new Sailuns at 105 psi. The problem with going way under the maximum pressure is the sidewall deflection when you are backing up sharply. I am also assuming you checked your wheels to make sure they are rated at 110 psi. Good luck.
