GoPackGo wrote:
Please - I do not want to go the LT tires route - or start up the debate again. I believe that the stiffer sidewalls of ST tires are what you want under a trailer. And I also want tires that have an adequate load rating (including a generous reserve).
The Sailun because it is an all steel ply tire with have a stiffer sidewall than your Maxxis tires or any other poly carcass ST tire.
The stiffer sidewalls of run of the mill poly carcass ST is marketing hype that does not exist in real life.
Sailun #2 is a good choice. You will not need to run them at 110 inflation. 90 or so should be fine. Make sure your rims are rated for the tires you purchase.
