valleybos2's avatar
valleybos2
SANIBEL OWNERS
WE JUST SOLD OUR 2014 ALPINE 3600RS BECAUSE OF WARRANTY ISSUES AND DECIDED TO GET A 2014 SANIBEL 3551. WE PICK UP THE NEW SANIBEL AROUND THE 15TH OF THIS MONTH. I WOULD APPRECIATE SANIBEL OWNERS LETTING US KNOW HOW THEY LIKE THEIR SANIBELS.
  • B.Sjulestad wrote:
    I can't help you with your question but it does look like a nice 5vr. At almost 15000 GVWR it might be too much weight for your F250 though.
    x2
  • GPG52! wrote:
    I had just asked a similar question but with regards to a CRUSADER 325RE... Here is one feedback that I found very interesting:
    "There is a known issue with the Darco wrap slide bottoms tearing where the rollers contact and Primetime has failed to respond on the Primetime forum. Owners are concerned about moisture problems.
    Go to the Primetime forum: http://www.forestriverforums.com/forums and do a search for "Platokidd". He started the current post on the issues."
    Good luck
    GPG
    I posted the link and the poster. Don't remember if the Sannibel has the same Darco wrap but if you go to that link and read through the posts you may find out. The Darco wrap is a woven-I think polypropylene- that is similar to house wrap. It is not the same as Tyvek. Although it is touted as breathable, I don't think it will prevent water penetration. For this reason I think it may eventually pose a rotting problem where the ends are exposed to water dripping down and curling under the edge. I am watching carefully and may spray with Rustoleum Leak Seal. I also added a piece of aluminum roofing drip edge on the corners.
    If you read the post started by Platokidd, be on the look for posts from RV Guy. I beieve he works for Primetime but has been silent for months on this issue.
  • Do you think that maybe you should have ask before purchasing the unit? I hope you like it! :h
  • I had just asked a similar question but with regards to a CRUSADER 325RE... Here is one feedback that I found very interesting:
    Good luck
    GPG
    It seems like whatever question is asked some people feel the need to bring up weight issues even though it has nothing to do with the question asked. Just saying
  • I can't help you with your question but it does look like a nice 5vr. At almost 15000 GVWR it might be too much weight for your F250 though.
