Thought I would update this thread now that I am finished this project. I bought a coax tracer and started tracking the wires and splitter in my trailer.
I was able to locate the main wire from the coax feed on the outside of the 5er and both wires from each TV jack. I was able to access them through an existing booster panel and installed a sat splitter. I am now able to plug my viewcube in the main cable feed on the outside of the 5er and get signal to my sat receivers without drilling any other holes to bring wires in.
I then hung my 32" tv at the front on a mount I installed using a 3/4 piece of plywood and found the studs behind the wall. Now I can use that counter space for my sat receiver and DVD and the TV can be turned for use in the bedroom and couch area in the 5er. Worked out exactly as I was hoping !
Coax Tracer
Outside Sat in jack
TV Mount
