Durb
Jun 26, 2018Explorer
If the 5er you are considering is relatively new it will most likely have a rounded nose cap which could open up your options with a short bed truck. If your intended trailer is older and has a square front then you will most likely need a sliding hitch which most manufacturers have in their line. The swiveling feature you mentioned might be a Reese Sidewinder which moves the pivot point from your hitch to the kingpin.
If you want to get versed on the majority of opinions that you will see on this forum, search the websites of the following.
- Pullrite Superglide (auto slider)
- B&W hitches
- Andersen Ultimate hitch
- Reese Sidewinder
- Goosebox ( if this is the adapter the salesman was talking about then it isn't a bad option given the right trailer frame)
- B&W hitches
- Reese Sidewinder
About Fifth Wheel Group
