Have any of you had a screw pop loose in your flooring. I have one that came loose in the kitchen area. You could see it pushing the linoleum up. I made a small slit in the linoleum so that I could...
See if you can get a small set of vice grips on it and unscrew it all the way out. You may have to make the cut in the linoleum a little longer but as long as you don't tear it or stretch it too much, you can glue it back down. You can replace the old screw with a little bigger screw it you need to. Take your time and it should not be noticeable.....
