Have any of you had a screw pop loose in your flooring. I have one that came loose in the kitchen area. You could see it pushing the linoleum up. I made a small slit in the linoleum so that I could...
We had the same event. In the cupboard under the galley sink. Lifted the lino right up so we had to slice it to expose the screw head. It was not stripped and tightened up nicely. We glued the lino back down and it seems to be holding up fine so far. I never did figure out what was on the receiving end of the screw due to coroplast and all.
