Have any of you had a screw pop loose in your flooring. I have one that came loose in the kitchen area. You could see it pushing the linoleum up. I made a small slit in the linoleum so that I could...
Remove the screw, drop some wood glue down the screw hole, stick a tooth pick or two down the hole, put screw back in and snug it up. It will stay in for a long time, longer than you'll own the RV.
