mhardin
Sep 23, 2019Explorer
I have used toothpicks with epoxy in the past and it worked well. When a larger screw holding the awning support pulled out, I drilled the hole a bit larger and used a dowel with epoxy. Re-drill a hole for the screw so you don't spin the patch loose trying to get the screw in.
About Fifth Wheel Group
