Gjac
Sep 24, 2019Explorer III
Over the years, I have used toothpicks, steel wool wrapped around the treads, epoxy, and wood glue to fix stripped holes. They all work if holes are not too stripped. What I do for larger holes is to cut a triangular piece of wood out of the corner of flat oak pallet board with a knife. The knife will follow the grain of the wood producing a tapered triangle piece. The triangle piece of wood is tapped into the hole and the over sized triangle will bite into the hole preventing the screw from spinning.
About Fifth Wheel Group
