3_tons
May 31, 2020Explorer III
valhalla360 wrote:
Are you putting bars across the windows too? If I was robbing trailers in remote areas, that would clue me in that something good must be in there and I should break out a window to see what I can find.
Of course, you also have the problem that the walls of RVs aren't that strong. I'm betting any kind of bar could be removed in under 30sec with a crow bar or battery operated angle grinder.
Just had to remove a padlock because I lost the key. Took me about 10min to find the angle grinder and hook up the cord. Grinder went thru the padlock like a knife thru hot butter.
Well that’s all quite true, in fact a determined person can break into almost anything - ones stick built house’s Front Door can be defeated with just a mere solid kick, but my intent has to do with ‘hardening a soft target’ as a deterrent... looking here for ideas of interest..I do like the robust lock idea that was mentioned above :)
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
