MFL
Apr 14, 2018Nomad II
If you followed the instructions on placement of the spring, it will keep the head level, to slight tilt back, to allow the pin to slide up onto the hitch, when backing under it.
The tool box will work, if you have enough clearance. Should be at least 6"s, but with TBX 8" inches would be better. You will know, once hooked up.
Jerry
Jerry
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
