cummins2014
Jan 05, 2022Explorer
humblerb wrote:cummins2014 wrote:
There’s always the option of the frame adapter , I wanted to keep my existing hitch, manual slider. There are three brands of those adapters , cheaper then a new hitch in the event you don’t get your old one sold . The adapter locks on the four pucks , then it works the same as the bed rails, but can be removed along with the hitch or separate.
Already talked to B&W about this.
They make an adapter for the Companion.
But, there is not an adapter for the Patriot and RAM trucks.
I believe you misunderstood me, your hitch was previously mounted to bed rails in your previous truck, this is no different other than its a separate frame that attaches to the four pucks, then you hitch mounts to that .you don't change anything on your hitch . Google Reese 30154 adapter, and you will see what I am talking about , the Reese is the one I have . PullRite ,and Demco also sells one .
They allow for any standard bed rail hitch to work with your puck system without doing anything to the hitch, other then mounting it the same as you did with the bed rails . The nice thing is it removes by unlocking the four pucks ,and remove from the bed .
About Fifth Wheel Group
