humblerb
Jan 10, 2022Explorer
cummins2014 wrote:
Let me add , its a solid connection that frame, it locks to your four factory pucks, and there is no movement or slop . The only movement you will have is the same as you had connected to the bed rails with your four pins, which on mine is nothing I can detect .
Its nice to go directly to the four pucks , and if I was starting from scratch , that's what I would do , but nothing wrong with this setup other than another part to take out if a clean bed is needed. In my case ,I don't bother there is no need for a completely clean bed . IMO its great option, the adapter with already having a hitch , and considering yours is pretty new .
Cummins2014 - Thanks for your info. As a guy born in the 50s, it is hard for me to just order major items on Amazon, especially items that weigh 75# plus.
I did go to the place where I bought the hitch 3 years ago. They do not sell Reese products, but the guy there grabbed a tape measure and looked up specs on my truck and the adapter, then went to my truck and measured the puck locations.
That showed me that the adapter will work.
It should arrive tomorrow.
Once I get it and get it set up, I likely will find why the slider won't work with it. But, with my long bed, I certainly won't need the slider. Just curious.
Oh yeah, I did pull the trigger on the 2021 3500 before Christmas.
Thanks again for your input.
About Fifth Wheel Group
