cummins2014
Jan 17, 2022Explorer
humblerb wrote:cummins2014 wrote:
The adapter will work very well, IMO a great choice, some have disagreed with the adapters ,but similar to bed rails other than it can be removed . Being born in the 40's I had no problem with the 75 lbs. FYI the slider although you don't need it will work just fine with the adapter ,no problem there .
Finding out after many trips with my fifth wheel my existing slider was not needed with both trucks I used it with . Previous truck Ford Superduty 350 short bed. My present truck 2014 Ram 3500 short bed , or as they call them now standard bed :) I now tow with the steel Andersen hitch ,that also attaches to my adapter on my Ram truck . My Reese 18K slider is more or less a paper weight sitting in my garage. Never have attempted to sell it, I may some day, or just give it away.
Got the adapter last week. Surprisingly, it was already assembled.
I put it in and just had to adjust thee front pieces a half turn.
Fits like a glove.
Also, the slider does work with it - not that I will need it any longer. I guess the B&W guy was just telling me what he had heard about the adapter.
Thanks again for the help.
Thats good to hear . Same here ,had to adjust a couple of the lugs , ,and never touched them again . The adapter is a great solution for an existing hitch that fit the standard bed rails , or the way to go if you want to go a hitch for standard bed rails ,with trucks with the fifth wheel factory prep .
About Fifth Wheel Group
