BradycallExplorerSep 23, 2017Semi to haulI'm considering buying a fifth wheel camper and if use a peterbilt to pull it. What is the height of a typical fifth wheel RV kingpin?
john_betExplorer IISep 23, 2017Most of the ones I have seen the hitch for the 5th wheel is aft of the axle and lower between the frame rails. They did not use the standard semi hitch in the standard position.
Related ContentTesla delivers there first semiSEMI camerashauling capabilitySemi's as tow VehiclesTow Haul Mode
