MFL
Sep 10, 2019Nomad II
Braces wrote:
If you add 2" to the inside of the wheel well you might face the possibility of the tires hitting the wheel well on some of our nice, smooth, no bump roads. Happened to me when I went up a little on tire size and hit a really rough road section.
You are correct...taking away 2"s of clearance in the well, would not work in most cases. I will be replacing, not adding. My FW is designed with a 6 sided 2.5" square tube aluminum cage. I will slice the Darco wrap that covers bottom of tubing, remove existing fiber insulation, replace with above mentioned, glue Darco back to solid insulation. I will be adding 4mm thick coroplast over the fix. I will still have nearly 3"s of tire to WW clearance as 4mm (a long 1/8 inch) is all that will be added.
My question/concern was raising the axles to remove tires, with the landing gear down, not connected to truck, causing stress.
Jerry
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
