Al_H
Apr 06, 2019Explorer
WaterJosh wrote:
Actually, you can do it without lifting the bed at all, thats how I installed our puck kit. You just need to be part contortionist.
A contortionist I'm not but wish I would have consulted with you before I started. I did work in a well equipped shop with impact so that made the difference. I used a bottle jack on top of the leaf spring to lift the box and you could see everything easily. The bolts for the puck on front driver side was the worst, had to use two extensions and go over the top of fuel tank to tighten those two bolts, the others were easy.
About Fifth Wheel Group
