Some good advice already. But step one, is to take your truck and loaded trailer to some scales. You can go to
CAT Scales then find one near you. If you can't check with a truck stop, RV store or tire store. If not google scales and your city name.
Once you know your steer axle, drive axle and trailer axle weights it will help. If the scale isn't busy and you can disconnect and weigh just the truck steer & drive axle will then tell you how much that hitch weight is putting on your truck.
Besides getting a weight distribution and anti-sway hitch I hope you have trailer brakes and a brake controller. If not you will need to get that too. As far as weight distrubition (WDH) I used and liked the
The Equal-i-zer Sway control hitch
