kemerExplorerMay 08, 2013Sewer Flush ??Just bought first fifth wheel, Just above the purge valves there's an inlet valve for a hose(threaded) that says "sewer flush". Am I correct in assuming that I should hook a hose there when dumping bl...Show More
MarkTwainExplorerMay 08, 2013AND MY INSTRUCTIONS SAY NOT TO TURN HOSE TO THIS FITTING ON UNLESS THE SEWER IS OPENAnd disconnect the hose when not in use so that it doesn't get turned on by a neighbor while you are gone.A friend of ours had his trailer flooded with Poo water. Trailer was ruined and had to be replaced.Yuck!BillX2, this happened to our neighbors down in Ariz. and they did have to finally just trade it in:(
Related ContentSewer Tank FlushSewer Flush LeaksSewer Flush which one?Sewer smell outside camper when toilet is flushedClear Sewer Adapter w/Tank Flush Adapter - Which One???
