kemer
May 08, 2013Explorer
Sewer Flush ??
Just bought first fifth wheel, Just above the purge valves there's an inlet valve for a hose(threaded) that says "sewer flush". Am I correct in assuming that I should hook a hose there when dumping bl...
da.bees wrote:
X2 ^^^^ Including the short clear tube. I often add 5 to 10 gallons of water to the black tank for the ride home. Never fails to be some paper and the water is colored when I dump it in the clean-out at home. I think that proves the rinser doesn't wash the tank walls very well.
