kemer
May 08, 2013Explorer
Sewer Flush ??
Just bought first fifth wheel, Just above the purge valves there's an inlet valve for a hose(threaded) that says "sewer flush". Am I correct in assuming that I should hook a hose there when dumping bl...
Bumpyroad wrote:Cummins12V98 wrote:2oldman wrote:agesilaus wrote:I don't see why that's a problem.
And don't use your drinking water hose to do the flush. .
It really is not a problem because the flush has a vacuum breaker. It just looks bad!
so you actually trust those cheap plastic anti flow valves? I don't.
bumpy
