kemer
May 08, 2013Explorer
Sewer Flush ??
Just bought first fifth wheel, Just above the purge valves there's an inlet valve for a hose(threaded) that says "sewer flush". Am I correct in assuming that I should hook a hose there when dumping bl...
kemer wrote:
Just bought first fifth wheel, Just above the purge valves there's an inlet valve for a hose(threaded) that says "sewer flush". Am I correct in assuming that I should hook a hose there when dumping black/grey water? I'm guessing that running water thru there will clean out the holding tanks. THANKS
