What fix is there for a methane gas bubble that forms in the toilet bowl when it's flushed. Is the vent stack clogged? If I drain/flush the black tank, all is good for a couple of days, but then the g...
Mine also burbs when it is getting full. It may just be that the tank fluid level is above the vent pipe inside the tank. Naturally that would impair the venting. I suspect most installers would install the pipe in the tank a little farther than we would prefer. As a solution, I do not flush with the tank near full, while sitting on the toilet. :)
