Over time the handles for dumping the tanks have become harder to pull. For sure do not want to break those off !! What does everyone use to lube the handles with ? Thanks !! :h
I agree with Jerry. The problem is usually not the handle or the wire leading to the valve, but with the valve itself. The valve lube does help some. I have had to take the black valve body loose and lube it a couple of times. Mine is relatively easy to get to but not the "funnist" job!!!
