Likepaperinafir's avatar
Sep 20, 2018
Sewer Rats!?!
So i went into my toyhauler today to dust it off for the first camping trip of the year and what do i see but a sewer rat poking its hand out of the shower drain....how do I get rid of this nasty thing...why is it there i never left drains hooked up anywhere....grrr....
  • Terryallan wrote:
    How did it get in there????? That is what you need to find out. Once you get it out.
    Maybe through the vent stack on the roof..?
  • How did it get in there????? That is what you need to find out. Once you get it out.
  • Ralph Cramden wrote:
    If you flood and drown the bastard you may end up with a dead sewer rat clog of epic proportions, especially in the gray tank with 1-1/2" or 2" drain.
    Good point. The 12 gauge is probably the best choice. :)
    How about removing the strainer on the shower floor so it can get out, then set some traps?
    I would set several in case he is not alone.
    Maybe jam the barrel of a 12 gauge down the vent and let loose.
    Might lead to some other minor problems, but I. Like it!:B
  • Maybe jam the barrel of a 12 gauge in the drain and let loose?
    Seriously....I would open the valves and then take an air hose or water hose and snake it in there. If you flood and drown the bastard you may end up with a dead sewer rat clog of epic proportions, especially in the gray tank with 1-1/2" or 2" drain.
  • I would fill and empty the holding tanks a few times. Maybe that will flush it out?
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
