sayoung's avatar
sayoung
Shackle bolts & bushings
Two questions actually, 1st anyone know the torque value when tightening shackle bolts on 3in axles ?
#2, looking at wet bolts or those " never fail bushings" , see lots of praises for wet bolts but no comments on the bushings.
  • just for general information 'wet bolts' DO fail. they seem to break in the center where the pin hole is. as for the bushings, they are 'plastic' material and you have to check on them just like the metal bushings.
  • rhagfo's avatar
    rhagfo
    Explorer III
    The value on the wet bolts is 50#, if taking the shackles off for any reason you should spend the less than $100 for a wet bolt kit with heaver shackles.
    These???
    Notice the slightly out of round holes.
    Or these????
