SDM
Oct 18, 2013Explorer
Shackle bushings
On the average do bronze shackle bushings last. I have a fiver that weighs 14500# when traveling. I grease the shackle bolts 2 to 3 times a year and before every big trip.
fj12ryder wrote:h2guy wrote:If so, then someone screwed up somewhere when installing/replacing them by allowing the bolts to spin in the hangers. The bolts won't move in the hangers if they are installed correctly, that's why they are serrated. If they aren't secured with a wrench when the nut is tightened they can spin in the hangers, which will result in movement and elongating the hole in the hanger. Sounds like someone was in a hurry and just used an air impact and the bolt spun.B.O. Plenty wrote:h2guy wrote:The bolts are serrated right next the head. If they are pressed in when they are installed as they are supposed to be, they are then locked into place and cannot rotate in the hangers. All movement from the springs or shackles will take place on the bushings, not the hangers..
I don't see where wet bolt kits will prevent your spring hangars from "ovaling" or becoming elongated.
Spring eyes will last, but not the hangars.
Got extremely tired of messing with them and had the "IS" system installed.
B.O.
When delivered to me, Carriage (or frame mfgr) did have serrated shoulder bolts installed. Hangars wore out anyway.
