Hi I was doing some maintenance on my 2014 DRV Tradition, 28,000 miles on it, and found both straps broken on the LH rear axle and one broken on the RH front axle. We just got back from a 3300 m...
Was everything original? If so, you surely got lucky you got this far. Like Don said, are you referring to the hangers or shackles? Hangers welded to frame. Shackles attach spring to to hangers? If no wet bolt kit, I certainly would go with one as you'll get beefier shackles, bronze bushings and the greaseable bolts. Not an overly hard job to do, but will take a a couple -few hours. I replaced the stock junk on our '18 Big Country couple months after we got it with a wet bolt kit. Love it.
