Don_A_L
Aug 12, 2017Explorer
Shackle straps?
Hi I was doing some maintenance on my 2014 DRV Tradition, 28,000 miles on it, and found both straps broken on the LH rear axle and one broken on the RH front axle. We just got back from a 3300 m...
Don A L wrote:If you change to the Dexter EZ Flex and wet bolt kit, the shackle straps will not be wear items. The EZ Flex and wet bolt kit is the way trailers should come from the factory.
The two metal straps or plates that connect the front spring eye to the center equalizer.
So they are a wear item on trailers? Definitely will go with heavy duty and wet bolts.
Don
