Any recommendations? Anyone out there that really hated those dual rear wheels but after a while just got used to them? Or am I being too critical on how much a 3/4 ton can carry? Those of you with 3/4 ton trucks, what do you consider acceptable?
The dually is no wider than the mirrors so the width should not be an issue and a dually is no longer than a SRW truck; but it can handle more weight and is more stable both major plusses.
I think the wife should drive one for a day or so and the intimitation factor will likely go out the window. l certainly would work through the dually issues before giving up after a lap around the block. Really, how is that a determnation of anything? But, if momma ain't happy nobody is! Good luck.
