wgm2011 wrote:
Any recommendations? Anyone out there that really hated those dual rear wheels but after a while just got used to them? Or am I being too critical on how much a 3/4 ton can carry? Those of you with 3/4 ton trucks, what do you consider acceptable?
Bill
Bill, you don't have to go 3/4 ton to get single rear wheels.
Look at some of the new 1-ton SRW trucks, they have pretty impressive payloads, over 4000# in some cases.
You do need to do the math (PIN WEIGHT) on any fiver you looks at as you will be more limited than with a dually, but there are lots of good sized fivers out there that a SRW 1-ton can cope with. Yes, even that 14K Big-Horn if the pin weight is a typical 20%.
