Michelle_S
Oct 28, 2016Explorer III
When we had a similar issue, it turned out to be the Converter AC Plug had worked it's way loose in the outlet. Reseated and used cable ties to keep the plug in and no further problems.
Also on some units if the Battery Cutoff switch is activated it will prevent charging the battery.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
