Toolguy5 wrote:
laknox wrote:
Toolguy5 wrote:
b-dog wrote:
Ended up getting w companion slider for my 2500 Chevy. Seems I'm going to have to remove the tail gate with the slide in the back position. Has clearance problem with the pin box. I can adjust the arms on the hitch up a 1" or 2"
I just purchased a 2015, 3500 Sierra and a B&W companion slider recently. I have only towed my 5er around the block. After reading your post I started thinking I better check my set up out thoroughly.
As you I have the arms at the lowest position to be level. I put the slider in the back position and I am only about an inch from tailgate, if I looks like if I try to turn a lot the Fiberglas shroud will hit tail gate. There is about a 1/2 inch I could trim before I get into actually pinbox frame.
I took my 5er and truck to an empty parking lot. With the hitch in the tow position I was almost at a 90 degree angle from 5er and still had about an 1 inch before I hit the cab. So I don't believe I would ever need to use the slider so I am not going to worry about tailgate problem.
Then my brother called me he just bought a older fifth wheel. He had no means of towing it home. He asked if I could. This 5er is only half the weight of mine. The bed clearance was only about 4 inches. It is a good thing I only had to go a few miles. Coming out of the drive way he bought from the dip and turn was so that the top of my tonnaue cover rail just missed rubbing on underside of 5er.
So this week I will spend time raising my arms on the hitch. I will try the highest position first. If it looks to out of level the I will drop it down.
Mostly for the simple reason if I had to help a friend in need I would have no issues.
Check the suspension on your FW while you're at it. You might be able to fairly easily raise it up, especially if you have multiple holes on the spring hanagers and you're not already in the lowest hole. It's also an excuse to slip in a set of wet bolts and bronze bushings. :-)
Lyle
Nope can't raise it unless I put blocks or buy a kit for it. I checked that out before hitch was installed when I bought the truck. I was worried I would not have enough rail clearance.
In the present position of mine I'm ok with it. But I will explore different hitch height just in case I need to help a friend.
I figure if I raise the arms 1 or 2 inches it will give me a little more rail clearance. With the arms in the rear position I don't really think I will need to use the slide. As I said I can turn almost 90 degrees with about 1 inch clearance of cab.
FWIW, my '02 D'max 4x4 CC, 6.5' bed, will not hit my very square front Komfort at full lock, left or right, when going forward. ALL will hit going backwards. I have a Companion, too, and have the side pieces as far forward and high as I could get them. I do tow slightly nose-high, but it's small trade for the 8" bed clearance I have, and =need=, when boondocking at our usual site. No tailgate or bed rail clearance issues with this setup.
Lyle
