b-dog's avatar
b-dog
Short bed with companion slider
Ended up getting w companion slider for my 2500 Chevy. Seems I'm going to have to remove the tail gate with the slide in the back position. Has clearance problem with the pin box. I can adjust the arms on the hitch up a 1" or 2"
  • Sounds to me like the taper on the back of your pin box is hitting your tailgate. If that is the case, the same problem will be there when you turn sharp at your bed sides. Take your tailgate off, then slide the hitch back, check the inside clearance of your pin box and truck bed when you turn.
  • You don't say where your hitch is presently sitting, however B&W Companion hitches are adjustable up and down, front and back.
    You may have some limited up and down adjustability on the fifth wheel kingpin too.
    Unless your truck is lifted and/or has very tall tires, you should be able to make adjustments.
  • I have a Reese 16K Pro Series in my 2010 Chev Silverado 2500HD short box and no problem with hitch slid back and tailgate closed.
